Ramsey PA-10 manual
Se7en
Well-Known Member
Jun 27, 2010
4,573
223
Ca
Can anyone help me find a manual, i have tried google no luck so far? or have a copy they can scan pdf? thanks a lot appreciate it
What are you looking to do with or to the amp that you need a manual? I had a PA-10 for a long time. It has no controls on it and only input/output SO-239's, power cord and an LED xmit light. 1-5 watts in gets you 20 -40 watts out. I added a power switch to it but you don't even need a schematic to do that.
5w in is getting me 25w out...
That might be about right. I think I saw 30 watts out of mine with 5 in.
With the current at 50mA. Or higher its supposed to produce 40w. Once I get it in the mail ill find out it probably needs some adjustments or new caps ?????
Sent from my Xoom using Tapatalk 2
If I were you I'd call or email Ramsey. If the PA 10 was a kit they may be able to send you the assembly instructions with test points, voltages, etc and you may be able to find the issue or bad component if there is one.
Will do. It works...like I mentioned in the previous posting. Sure looks nice inside and for $19 shipped I am stoked.
