Yaesu RTS question
Se7en
Well-Known Member
Jun 27, 2010
4,573
223
Ca
This is dealing with the Yaesu FTM-350 software for programming.
IF you click on Left VOF's tab, my GR1 is empty. what is it supposed to be set at?
another question is there anyway to hack it to add 6m Receive?? or 30-50mhz receive?
I use G4HFQ's FTM-350 software so I can't answer the programming question about the RT Systems software.
However about your second question - no, there's no way to hack it to receive 6m or 30-50 mhz.
ok
GR1 default settings are:
Receive Frequency Transmit Frequency Offset Frequency Offset Direction Operating Mode Name Show Name Tone Mode CTCSS DCS User CTCSS Tx Power Skip Step Clock Shift Comment
222.00000 222.00000 Simplex FM 0 None 100.0 Hz 023 1500 Hz High Off 12.5 kHz 0
Thanks.! I put in 300mhz lol ill change it in the morning
