Dead Mod on DOSY PM-2001-TS
JJim
Jul 2, 2005
29
www.yoursaftnet.com
Has anybody seen this or have an answer based on common electronics knowledge?
I have a "used", of course, DOSY PM-2001-TS meter. The SWR and Power seem to work just fine however, the Modulation Selection is dead.
I set the "Set/Mod" switch to Set, I turn the Dial to MOD and key the mic, but get nothing at all on the meter. I did put a Fluke meter on it and here is what I found. With the Fluke on Diode / Beep test, 3 of the diodes inside of the DOSY give me a dead short (constant beep). Is it possible that these diodes were blown due the the last owner using this setting with linear hooked up? The 3 diodes giving this reading are: D7, D8, and D10
D10 - .007
D7 - .003
D8 - .018
Anybody? Help?
-jim
Yes, That is very possible. I have a TC-4001 meter. You can go to there site and get a manual . It should be easy to change the diode. I called there tech support and they emailed me a schematic of mine so I would know which pot to turn to adjust the ranges.
http://www.dosy.com/pm2001ts.php
Good luck
Good luck
this is more a question then a quote but here goes. I have the tc4002psw meter . I get very little mod swing and nothing on any other settings.Could the same problem exist in my meter?:thumbup1:
I'll answer my own question. I fixed it. took the cover off and looked and looked at the wiring and the other stuff in there and I hit it by accident. a wire was disconnected from the board in there ao i got my iron hot and put it back together.Saved my $170.00 from buying a new one.
