yes... no.... maybe? "X" antenna.
  • Thread starter Thread starter oldslowchevy
  • Start date Start date
O
oldslowchevy
Guest
i know i know, you all are getting tired my dog on dipole questions. but while at work i had a couple of ideas, and before i start building something that could burn up my radios tring to tune i figure i should as you guys.
what about an "X" type dipole antenna?
i see it working 1 of 2 ways.
way 1....
have the coax come up in the center and attach each element being bent in the middle.. ">" then the coax "I" then the other element "<"
so it would resemble ">I<"
the other way i see it might would be crossing the elements still joined in the middle.
one element would go "/" the other "\" and the coax joined in the center to look like a big "X".
i have looked on line with no luck.... maybe i am calling it the wrong thing?
hummmmmm not much towards what i am looking for.
how to build.
calulator for lenght
an idea of performance.
lots fo satalite and 80 meter as well as some for 2 meter, i found nothing yet for 10-12 meter.
i guess there is a reason for that though.:redface:
What you're asking about is called a Turnstyle Antenna. Google that and you'll have your answer.
Mike
looks like it would work really good but seem like it would also since i can not find a calulator to detreminum the size, but from what i am reading it does seem to be very large, much larger than i thought it would be.:oops:
Size? Figure on a 1/2 wave dipole for length. If for one band, then each leg is the same length.
i will be using it on cb (11 meter) and my dipole is appox 17 foot.
so will each leg be appox 8 1/2'foot times 4
or will each leg be the 17' making it 34' long? i am thinking 17 by 17 is what you mean.
ok, i now have this built and the recieve is very good. though i can not get the swr below 4.3:1. if i make it shorter even by just 1/2" or longer by just a 1/2" the swr jumps to beyond what me meter can read.
i have been tuning, rebuiling, tuning for 3 ays now.... what am i doing wrong?
18' coax, into home made balun, then soilered on to the center of two 17'4 9/16" 12 ga insolated wires running 90 deg of each other.
ideas welcome.
