Wilson lazer 400. old version...
Zman
K9FON
Nov 26, 2009
984
113
I picked up a totally NOS Wilson Lazer 400 made in the mid 1970s, however, it didnt come with a direction book. Upon looking at the gammas the feedpoint and the way the gammas hook to the elements is completely different from the Maco version of today. Does someone have a copy of the directions i can have????
Zman, does the bracket for the SO239 have a short wire connected to its tip, and a small hose clamp that fits the bottom of the gamma as noted in the image posted below...at the other end of this short wire?
As I recall, there is also another bracket that supports the bottom of the gamma that is a short piece of aluminum stock maybe about 3.5" x 1/4" with a plastic clamp attached to one end and a bolt hole for the driven element u-bolt on the other end that looks like this?
That kinda helps. Where did u find that?
I was looking thru some only manuals for my Wilson Y-Quad instructions so you could see how the gamma was setup, and I found this.
I have no idea where it came from.
The way the gammas fasten is the only difference between the Maco and the old Wilson. Ill dig into it more when i finally get the beam home. I lucked out finding this NOS Laser 400! The guy also has a NOS Avanti Moonraker 4 as well as a PDL 2 and a Wilson V 5/8 (similar to the maco V 58).. Lord knows what else he finds as he cleans the attic in his shop, LOLOLOLOL!!!! :)
