what antenna would you use for CB on this car and why?
Same answer as in the other thread. If 'looks' makes that much difference to you then get whatever you think would 'look' the best.
I use the ratshack 5.5 on my saturn and it works great. I have run a 102" for a couple weeks and didn't notice much difference. I run barefoot, no power adders.
102 SS whip
I would put the 102 + 4" SS extension + 3" quick release midway between the front and rear bumpers and in the center line of the roof with a puck mount. That should improve the looks of that or any vehicle! :thumbup:
All kidding aside that worked just fine for my ford ranger extended cab for years and fact of the matter is, as long as you are in the vehicle talking on your radio you won't worry about what it looks like outside.
Good luck with whatever you decide.
You must be kidding.
nope.
I don't recommend it for garage parkers, but my best mobile setup was a 102 off the trunk lid on my '82 malibu. he doesn't have a deck lid so...
if I had had a roof rack, I'm sure I would have put it there.
height makes might.
it does limit your drive through options though.
