1X4
Depends on who built it and why? Reason I say this is normally the driver is a 2290. This means it was a custom build, probably class C. Running hard wide open you might see 70-90 amps draw, 50-60 taking it easy and talking normal.
Reactions: 2 people
XT400
Transistors 2 SC2290 driving 4 x 2SC2879
Dimensions H** 4 1/4**" x L 11 x W 6 3/4"
Amp Draw (maximum) 100
Class C
SSB Delay available
Pre-amp available
No Driver Required
Power Output (RMS) 450 Watts
Power Output (PEP) 1000 Watts
NEW!! Choose your LED light colors!
** NEW ** ADD MODULATION LIGHTS TO YOUR AMP!
XM400
NEW medium driveTransistors 1 SC2879 driving 4 x 2SC2879
Dimensions H **4 1/4**" x L 11 x W 6 3/4"
Amp Draw (continuous) 40
Amp Draw (maximum) 85
Class C
SSB Delay available
Pre-amp available
no Driver Required
Power Output (RMS) 400 Watts
Power Output (PEP) 900 Watts
Driven Power (RMS) N/A
Driven Power (PEP) N/A
If it were me Ide get a 100 Amp reason being is it will leave plenty of head room or breathing room due to the extra Amps available people run there supplies hard and the more you run a supply taxing it out to its limits your obviously takink or robbing it of its lifespan. ;)
I like how X-Force now calls the 1x4 all 2879's their med drive. If they want to come out with something new give us a nice regulated AB fan cooled line with switched SSB delay.
