VX-8DR tx issue (Im a newbie)
Mako
Mar 14, 2013
7
Hello, im completley new at this stuff so i hope i understan any responces i get back. I am unable to transmit to a frequency that i can hear ie:150.890 simplex. I get the red indicator light as if the radio is transmiting however nothing goes thru to the other radio. Pls help i can give my phone number if a verbal is required.
Unless you have modified that radio for out of band transmit, it shouldn't be transmitting there.
Is your the US or EU radio (not sure if that makes any difference)
If the red TX is going on, that means it is transmitting. Can you try listening on a few different radios to make sure the problem is on the RX end?
Tone squelch on the receiver?
Transmitter's "shift" turned on? Is the display showing the correct frequency when you key it up?
