Mobile H2
My brother in law had an H2 a few years back. He waxed and buffed it incessantly. I picked my nephews up to go trapping one day and noticed he was getting ready to start his ritual.
I crawled underneath real fast and tightened a large 3' zip tie on his drive shaft. Got a text few hours later wanting help diagnosing a terrible noise.
Great fun that was. I still have a handful of those ties. Need to find another culprit.
Reactions: 4 people
If you really want to get'em good, a hose clamp or wire
What works real well is the " Fold Down " 110 inch whip.
made with a Hustler Folding Shaft and a cut down stainless steel whip.
(that's what the loop body brace is for) the SWR stays at 1.3 to 1.5 at max
power out. Thread in different whip lengths for freqs you need to work...
Why are you using the Yaseu when you have the ICOM that has UHF/VHF already? Even though the ICOM covers the same thing as the HR-2510, I can understand you wanting to use it due to the reported audio quality (never had one don't know first hand). Seems like you could do some consolidating?
You can't be running DX on 20m while monitoring the local 2m or 70cm repeater with just the Icom. You can also be talking away on the repeater while scanning or listen for a DX station. I always ran an Icom IC-2000H 2m radio as well as a Yaesu FT-857D in the mobile for that very reason. Same thing at home. I run a separate 2m radio in addition to a separate 6m receiver even though my FT-857D covers both those bands and more.
It,s not 102, it,s 110 inch for 10 and 11 meters. there is a 1.6 on 11m with a 2kw dead key.
the antenna works well. it seems to favor the larger diameter aluminum shaft loading into
the more tapered stainless steel whip. it makes a really nice taper form the mounting ball
to the tip of the whip. the stainless steel whip can be replaced with different lengths ,
for Freq's you want to work....
