Does the DX-949 have the same board as the DX-959 to me I like the 949 better and would conect the external counter with a 6 th digit, the features all look the same.
op:
Naw; they don't change that much . . . Sounds like you had a lot of bad experiences with it . . . So did I . . . At first . . .With a Galaxy radio your better off not seeing that last number..........constantly changing, lol.
They can hold freq well enough after they have been on long enough in a comfortable environment. I'm certainly no great tech; but can get them aligned with no real problem. I have seen more than a few Galaxy radios and have aligned them. They really do respond well to a proper alignment and TLC ('tech looking carefully') for proper solder joints and other known problem areas.
After aligning the receiver with a SINAD meter, the receive is more than acceptable. Sometimes the AGC mod needs to be performed if the receive on SSB sounds a bit trashy; but the mod cleans that up well enough.
Either the 949 or 959 is fine. Same basic chassis - IIRC. I prefer the 959 because the freq counter only really becomes useful after the P5/P6/xtra freq mod is done to it.
