Retevis is giving away ANOTHER RA89R Radio for Independence Day! Click Here for more info!
I have done the W2ENY elements and back to back testing here with another station 30 miles away on ssb, the radioshack element sounds better, and several locals here that were listening and a couple dx contacts the same night also agreed
you can mount the element many ways, I found these round radioshack boards make it easy to mount, you place the element through the center holes and trim and bend over the pins, the board gives a nice place to solder the element and mic leads to, 1k resistor works fine and yes put the resistor just like the pic shows, no heat shrink needed
I just installed this element & res. Audio is weaker than with the stock element, smoke & mirror mod if you ask me. I guess it sounded too good to be true for under $5. Either im just gonna buy a used head off Fleabay or buy the mod from RB Micro. I kinda knew it, lol.
are you sure everything is correct,, I have several of these that I converted and they are working great, plenty loud with the mic level turned up on the base of the mic,, I only had 1 that gave me some issues and it ended up being a bad mic cord. the guy I talk to almost every night uses one with this element also and his radio sounds great on my end
The American Radio Relay League (ARRL) is the national association for amateur radio, connecting hams around the U.S. with news, information and resources.
