solve for X...
subtract one frequency from the other and divide by 2 and add the result to the lower frequency indicates
x3 originally was labelled 10.825
by the same metric
x2 was originally 13.1575
you will have to get the crystals cut especially for the task most probably.
international crystal is here in Okla just about 15 miles from me. I have used them before to make crystals for what I needed. the building they are in is from the early 50's or older. they always needed the schematic for the radio I was having crystals made for so they could build them right. they do a good job. if it is some thing they do not carry it is rather expensive for a crystal to be made. last time I used them was about 2005 and the crystal back then was 20.00 to make it.
