i have a 2x sd1446 palomar amp or similar, i know the sd1446 are rated at 75 watts. my meter shows it keying up with a 2 watt carrier going in at 80, 150 , 250 watts for low med high power, is this possible? i fairly certain the meter is accurate at least at the lower readings because i know my radio is set to 2 watts on low power and its is right on the reading. ( not to say thats an accurate way to judge my meter buts its all i have)
