RCI 2980 WX transmit POP noise.
Staybolt
Mar 20, 2013
1,098
461
113
My 2980 WX makes a pop noise whenever i key it up. It does it with the stock mic as well as the desk mics i use.. Is there a fix for this???
hmm yeah you have me beet on that one... I only get it with my power mic but it sounds the same I hope some one can chime in on this one ....
will it help if you turn the mic gain down?
Well i guess nobody has any idea how to fix this problem.. Might have to call Ranger.
Hi. I have one of the old models before they put the WX on them. It does this on key up and un key. I also have a 2995DX NEW radio that does the same thing. It doesn't matter what mic I am running and if I am running an amp or bare radio. Did you ever find out anything on this?? It is a minor nuisance too me. It is load popping when I key up and un key as well. I think it is a common thing with the Ranger "Big Radios"... may not be anything to do for it.
check
and see if the limiter is intact. they pop like that
when the mod limiter is removed.
It almost sounds like audio feedback. I heard the pitch change on both mics. If you stretch the mic cord on the hand mic out a couple of feet from the rig does it still squeal? Turn the mic gain to zero as well. It's a front firing speaker and the desk mic looks like its almost right up against it.
I have the "pop" in the speaker on a stock rci 2950dx when I key or unkey the mic also.
Sure is annoying. I can't remember if it did that from "day one", or if the pop came later and I just didn't notice it right away.
