Retevis is giving away THREE radios for their 16th Anniversary! Click Here to enter!
Absolutely. What makes a good path for DC doesn't necessarily work for RF.
A good indication to see if your bonding is working is to use an antenna analyser. Note the frequency where X=0 and start bonding. Start with the horizontal surfaces - the hood and trunk or pickup bed - then re-check. You should notice that the frequency where X=0 has dropped. Using a lip mount I saw a drop of 300kHz by the time I'd finished.
Flattened RG213 braid makes for a good strap. Wire isn't suitable as it has a very small surface area and as RF flows over the surface of a conductor and not through it, we want as much as possible.
Bonding of the exhaust and engine to the main body helps reduce electrical interference.
Yes that website is great for explaining stuff like this. I plan on doing a hard mount as soon as I get my new vehicle. Untill then I have to make due with a mag mount. Trying the make the mag mount as effective and efficient as I can.
Grounding the radio case to ground helps. My 959's case ground isn't the same as it's (-) ground wire. Doing that stopped my K40 magmount antenna I had at the time from having a floating ground.
Then that's K40's bad advice then. I got the advice from them. It solved my constantly changing swr reading.
Let me say again,my Galaxy DX-959's ground wire is at a different potential than my 959's case. They might have had something to do with it but K40 told me that I had a floating ground and that grounding the radio's case to let's say,the same ground point as my 959's ground wire,which I did,fixed it.
As I said I have been on that website. I got a lot of good info there. I had a more specific question though. Should I use one or two ground straps on the hood? Should I then connect the strap from the hood to the fender to the frame? This is not on the website.
I use short pieces of old RG8 coax braid. Really wide strap is not really necessary unless you are running lots of power. It's all about the RF currents that each piece needs to carry. If in doubt use two pieces. Anywhere there is a hinge like doors,hood, and trunk should have a strap bridging the hinge.Exhaust should also be bonded in at least two places.
