Please try and restrain yourselves and limit the laughs and wise cracks.
Sirio Balcony 27 W 10m & CB Base Antenna, DNJ Radio
The vertical is 8.6 ft.
The radial is 3.7 ft.
I know this will be somewhat directional in the direction the radial is pointing. And I know a single radial doesn't provide much of a ground plane. And one only 3.7 ft. in length provides even less.
And the story on this appears to be difficulty in getting a good SWR, but am guessing that has something to do with these mostly being mounted on balconys and window sills since that's what it was designed for.
However, if one was to mount the antenna 15 ft. in the air away from any obstructions, and point it in the direction one mainly wants to listen and talk, what kind of performance do you think could be expected?
Thanks!
Thanks!
