40 amp or larger rocker switch
Not in most stores...they are 30a versions.
I'm done here...
Sent from my SAMSUNG-SM-G730A using Tapatalk
I just checked AutoZone which has stock, and even Radio Shack shows stock in my little pee hole of a town ... so I dunno *shrugs*
I'm done here...
Is that because absolutely everyone else in the thread can manage to find a 40A relay at their local store?
:D
Even if it didn't fit a standard relay holder why would that matter given the OP is going to use it for a custom application? As long as its got terminals on that he can hook his wires up to that's all that matters.
This thread got a little chippy :)
In the end I just relented and picked up a 40 amp toggle at a local hardware store and it did the trick.
Nice styled 40 amp rocker doesn't exist for future reference. I did find some 50 amp rockers but they aren't something you'd use in a vehicle. There are some styled toggles (kind of like what you'd expect to find in a drag racer) but they get a little pricey for what they are.
I did find some relays in the 40 amp range but the toggle was the simplest solution for my needs.
Thank you for the help everyone.
