Mic recomendation.
  • Thread starter Thread starter Peddler 356
  • Start date Start date
P
Peddler 356
Guest
I would like a honest recomendation for a hand mic to go on a Magnum 257, and a Titan II Road pro. I have a RK56 on my Connex 4800DXL mobil.
I am leaning toward a 575M6.
Any response would be appreciated.
Jim <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/pimp.gif ALT=":hat">
CDX-356
Meandering to a different drummer</p>
I have a 575M6 on my RCI 2995Dx, Galaxy Melaka and Galaxy DX99V. Nothing but raves on all three. I love them.<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D">
</p>
I too like yhe 575's but for my Titan in my tow truck I'm going to try a Road Devil (n/c power mic.) and see how it does. Will post results after I get it set up<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)">
<img src=http://www.chargerscastle.com/cbclub/hook948.gif>
Hot Rod Lincoln -Dancing around the World ! ...... 948 Central Texas, PE948 - Hook948@hotmail.com</p>
I run an Astatic 636l n/c mic on my Blackhawk and get a lot of excellent reports. You will have to turn the modulation up a bit though.
fasteddy
CDX-765, PE765
High Country DX, HF Specailist. Del Norte, CO
contact me at pe765@aol.com
</p>
Stock Microphone Rules.. mic gain wide open, full output on heated boxes and no feedback or squeels going full throttle.. just my opinion..
Of course on a Barefooted Radio is another story, Astatic Teardrops Rule..
</p>Edited by: <A HREF=http://pub86.ezboard.com/ufour6zero.showPublicProfile?language=EN>four6zero</A>
at: 3/28/02 6:47:55 pm
575M6's are the way to go!!! I run one on the mobil as well as the base. I like the way you can adjust your volume and your tone right on the mic.
</p>
575M6 hands down!
Handles: CDX-66, 66 in the Buckeye, The Kilted Yak
Equipment: President Lincoln, Astatic 575 Microphone, Predator 10K on a Triple Magnet Mount, Joker 2 Pill Regulated AB Bias
</p>
the 575m6 or just a regular stock mic in the mobile is uaully good and loud....
<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/pimp.gif ALT=":hat"> "ARE YOU DOWN WITH THE CLOWN ? ? ?" <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/pimp.gif ALT=":hat">
</p>
Hook,,,Did you ever get that N/C Road Devil "HOOKED" up?
The Peddler CDX-356,
Well the Titan just arrived at #7's shop. Gonna let him do a thing or two to it<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> I will order the Road Devil tomorrow so it will be a little while before I have it here and all set up<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D">
Can anyone tell me what the wiring is for a 575 m6 to the new president lincoln II radio? I have a 575 and I want to use it for the Lincoln. Thanks!!!
Depends . . .
If you are running a diesel tractor; then a noise-cancelling mic is best to elimiate road and diesel noise getting into the mic. I still think the original RoadKing RK56 is really hard to beat as a noise-cancelling mic. Sounds smooth and full and cancels really well. Not cheap; but worth every penny.
Astatic 636 or the Road Devil? Meh . . .
As for power mics/mobile?
A D-104M6 works great with the 270k resistor clipped, the RF Limited CR-577 is OUTSTANDING, and that is what I use still. If you can find a decent 575 w/o getting robbed buying it, that would be acceptable too.
I run a 575 on my Lincoln II.
The wiring for an Astatic 575 to the Lincoln II is the same as it would be for the Magnum 257 or Delta Force.
White-1
Black-2
Red-3
N/C-4
Shield & Blue-5
N/C-6
As it's been pointed out many times, be careful with these radios because pin 6 carries voltage and incorrect wiring can cause damage to the radio.
