I did this mod and diodes, not a night & day difference but my recieve is much quieter. When my locals complain about their high noise level, i look down and my needle is at a 1-3db. Worked for me for $12, lol.
I'm a bit gun shy about buying transistors from China. The IC's I've bought (regulator, audio, op amps, etc) from China have all been first-rate quality and were far below eBay's regular market prices compared to the US vendors. But as for final transistors (2sc2166, 2sc1969, etc), all have been bogus. Never buy final or driver transistors from China!!!I think that the MPSA18's AC current gain at 27 mhz (3.70) is far too low for it to be a good replacement for the 2SC1730L ( 40.8 AC gain @ 27 mhz). New China 1730s are available on Ebay and Craigslist. I would try those first.
- 399
giboni -
From my initial post:
AC Current Gain (hfe) ... is defined as the ratio of the input current to the output current in a device, and depends on the operating frequency. Ft and hfe work together to define the overall AC gain of the transistor at a specific frequency (fo). hfe is calculated using the formula: hfe=Ft/fo. (Where fo is the operating freq.)
Example: For the 2SC1730L at an fo of 27mhz, hfe=1100/27=40.8
I just bought some 1730's on eBay and will try them out soon . . .
Will do it very soon; going to replace both the AM and SSB transistors in a Galaxy 99v . . .Ok its been awhile. Im like a coiled Spring. Did you check them out these 1730's ?
Best John
