shortened 80 meter antenna
KD2GOE
May 30, 2013
950
219
173
43
Buffalo
Just want to share my 80 meter antenna i just made. I don't know how well it is working but i made 4 contacts on 80 meters last night. 2 where on the west cost. I am in New York
The antenna is 14awg 28' to the coil then 11' after the coil is warped around a 4.25" OD pvc pipe with 17 wraps total length of the antenna is 78' 6".
I still have some tweaking and ill get some swr readings when it gets nice out ill play with taking raps off the coil and extending out the 11" end
I hope this helps some one
Reactions: binrat
nice, whatever works,, all I have is an end fed 53' wire with a 9:1 unun balun.. you going to be on 80 tonight??
yeah i can be ill Mosley be tuning around i am still a little shy so i just like to jump in on peoples QSO's
Put up an antenna as high as you can.
Make the antenna as efficient as you can.
Get a BIG honking amp ( loafs at legal limit )
Key it down and make some room on the band.
Welcome to the 80 meters outlaw band, sometimes it makes 11 meters look like childs play.
Reactions: KD2GOE
:LOL: living around a lot of homes in the city ill have to run 100 watts QRP :D
75 meter phone frequency really does not cause any RFI that I have noticed, I have my computer speakers turned on and i am using legal limit into a dipole and i do not get any rfi.
I DO use good 1:1 current baluns at all feed points of my dipole antennas
    AKA- UDX122
  • @ nfsus:
    RFactive has left the room.
