Cobra 148gtl sound
kaos513
Apr 10, 2014
2,391
734
123
47
Putnam county,NY
Hello guys I have a cobra 148gtl has receive based on the meter and transmit and pushes out audio but cannot get sound on spearker or internal speaker also when I opened it up there was a purple wire loose goes to cb/pa switch but I don't know where it goes to board maybe that's my problem? thanks
It goes to the board nestled in between C173, C174, and C208. Those 3 capacitors are located right next to the audio IC (TA7222P or TA7222AP) and the AM pass regulator transistor (C1419 or D1135). These are located on the back right of the radio, near your +12V plug in.
Hope this helps. :)
~Cheers~
Reactions: kaos513 and Robb
Hope this helps. :)
~Cheers~
You sir are the man! the radio works again thank you very much.
