88 IRF520 Conversion Help?
Inquietude
Jul 5, 2014
21
20
13
Hi,
I'm right in the middle of converting an 88HL to 520's driver and finals using the CB Tricks/Euro Radio write-up and I've come across some old threads elsewhere about having to change a coil that isn't listed there. Is there an inductor that needs to change or be modified in some way? Is there a more complete source of information on the mod than what I have? Thanks in advance.
73,
Inquietude
P.S. Specifically, L33 and L34, and these were mentioned on a Defpom thread. Tnx.
Thanks, but I have all that and it doesn't mention anything about changing L34 as mentioned elsewhere (albeit with little or no details).
I did about 10 more minutes of snooping around and answered my own question about how to replace L34. Continuing the project.
Like to hear what you find; so could you please post the outcome?
L33 is the 54mhz trap circuit - IIRC . . .
No, it wouldn't be. Not if it's in series with the output. Traps are usually in parallel. TX alignment calls for peaking L33 for max output. But forget L33 altogether......
The answer is look at a Galaxy DX radio that came from the factory with dual mosfets and follow that.
Reactions: Robb
Don't see a schematic for a dual final MOSFET Galaxy.
Do you have one?
