If it works and can be calibrated then it is definitely worth it.
Waiting on my probes hopefully it will work as it powers on so far.K thanks
Do you happen to know where can i get the manual from? ThanksI use oscilloscope probes for mine works good.
http://www.themeshit.com/tektronix-cfc250-manual.pdfDo you happen to know where can i get the manual from? Thanks
Thanks but dont see any info on the counter just some comments.
Thanks ill keep trying as alot of the manuals online give me pdf error thankshttp://www.tek.com/manual-topic/getting-started
Use the search engines like bing or google
How can you tell if the frequency counter needs calibration?Thanks ill keep trying as alot of the manuals online give me pdf error thanks
Good question. Aligning a radio is useless unless the counter is accurate as well. There are a couple of ways to accomplish this. The first, is to use a ham rig and tune it to the 10mhz WWV station as a reference souce to compare your counter with:How can you tell if the frequency counter needs calibration?
