Yes on/off switch has 13v when switch is offThat is not a transformer, it is a choke. And no flow thru it means it shouldn't make any sound whatsoever without a load. Did you look at the schematic yet?
Did you check the on/off switch for 13v yet?
I tested the tranfomer on dc has zero readings on ac i get 0.167 voltsThat is not a transformer, it is a choke. And no flow thru it means it shouldn't make any sound whatsoever without a load. Did you look at the schematic yet?
So your saying i have a bad choke on the board?That is not a transformer, it is a choke. And no flow thru it means it shouldn't make any sound whatsoever without a load. Did you look at the schematic yet?
What about when the switch is on? Did you trace it with a DVM back to the voltage regulator? Why did you take the voltage regulator out?Yes on/off switch has 13v when switch is off
Doubtful. Did you check for DC voltage before the choke?So your saying i have a bad choke on the board?
when i test the choke gives me sperattic readingsDoubtful. Did you check for DC voltage before the choke?
he said the radio has been setting for a while now. did it work before it was left setting. if so I would be leaning more to bad solder joints or bad capacitors since the radio is as old as it is. yesterday I pulled a super star 121 off the shelf that was working before I put it up there and it was not working when I pulled it off the shelf. found some bad solder joints around the audio IC that had gone cold.after a few minutes of reheating them the radio is back to working now.
I did recap the radio with the correct replacements I used Panasonic high grade caps, still get the same results.he said the radio has been setting for a while now. did it work before it was left setting. if so I would be leaning more to bad solder joints or bad capacitors since the radio is as old as it is. yesterday I pulled a super star 121 off the shelf that was working before I put it up there and it was not working when I pulled it off the shelf. found some bad solder joints around the audio IC that had gone cold.after a few minutes of reheating them the radio is back to working now.
d44 was my issue, working on getting the am,ssb power back and audio back.he said the radio has been setting for a while now. did it work before it was left setting. if so I would be leaning more to bad solder joints or bad capacitors since the radio is as old as it is. yesterday I pulled a super star 121 off the shelf that was working before I put it up there and it was not working when I pulled it off the shelf. found some bad solder joints around the audio IC that had gone cold.after a few minutes of reheating them the radio is back to working now.
Its alive! Tr-34 went bad.Again, what looks like a 'transformer' is actually a choke.
The voltage shouild be the same as the supply voltage coming in - which is 13v.
Tell me; just how does a transistor responsible for SSB ALC control have ANYTHING to do with repairing/checking the power input and your 'transformer?'!?Its alive! Tr-34 went bad.
