imax 2000
When it comes to performance, one antenna pretty much performs like the next, assuming you get it to the same tip height. All the length of a longer antenna really does is get the part of the antenna that radiates the most higher up than on a shorter antenna. If you compensate for this by using a longer mast with the shorter antenna, you won't notice the difference unless something else is going on with one of the antennas.
The DB
The DB
i'll keep that in mind
