I disagree, direct injections is for people who want to take their skills to the next level. Direct inject isn't just for idiots but people interested in improving their knowledge of AM radio, CB and Ham included. How dare you suggest its the latest craze for idiots, people for the most part are interested in improving their audio quality and people like you should be ashamed.
Direct injection is done by people who have heard something that sounds cool but they don't actually have the first clue about what they're doing or in many cases even why other than its something someone said is good, you are also included in this group. You don't even know what the hell you're doing or what you should be adjusting for when you set up the EQ and you're telling me I'm wrong.
You do not need to directly inject audio to get good quality audio and if you did the only valid reason to do it would be to bypass the microphone pre-amp because you have a source with a lower distortion factor and the place that is valid to do it is immediately after the microphone pre-amp.
It doesn't improve their audio quality as they think it'll do and very few of them if any bother to listen to their own transmissions through another CB or ham radio but because they can hear it on the mixer monitor they assume that what they transmit sounds the same. It doesn't. All you have to do is look at the receive bandpass for your radio to see why. Unless you modify the receiver circuit, fitting wider filters or removing them altogether, on most radios most of the audio outside of 100Hz-3kHz never even makes it to the AF stage let alone the speaker so you can hear it. You'll see these halfwits making adjustments at 6, 12, 18kHz as well and that definitely doesn't do anything even on ESSB.
They're also not even focussing on altering the right frequencies because they have basically no idea how human hearing works so they whack up the bottom end too much, don't do anything much around 1kHz and end up with something that sounds booming, which basically seems to be the goal of these halfwits, but is actually not that easy to understand. And then when people are saying they can't work out what they're saying they up the mic gain.
And in the meantime they've got a signal splattering 30kHz wide whenever they transmit. I've watched these people on a waterfall on my Flex 6500 and not one of them has had a signal that is narrow enough to fit in a single channels bandwidth.
I shouldn't be the one who is ashamed because I can get good quality audio and stay within the bandwidth limits of the band, the RX bandpass filters of those listening to me and channels I'm using unlike you and 99.9% of these halfwits.
Here's a signal from an Italian amateur who is infamous over here and who has the kind of audio you want. His signal is over 10kHz wide
