I found this one, but I haven't verified it is correct yet. I need to come up with a list of parts, and I may as well recap. Any recommendations of where to order from?
Reads a lot like a joker would type...I felt like I had to rescue this little Philly after I read this ebay description:
Here a nice,powerful Cobra 25 ltd Classic, Got Variable to see zero deadkey & Echo board,1/2 swings to 18 easy,no mic or back plug in radio AS IS NO RETURNS make me a offer very strong radio, works alsome,had tech put in on bench,make someone a good talker or put in front of amp an turn deadkey down,talk all over .Happy Day USA STRONG,Smoke Free found a plug in I send but no mic I use it,An Fast Free Shipping Thank You
Thank you for sharing this, a "proper" variable dead key for the 25/29!
Is there a variable power mod that maintains a good swing ratio? I have never seen one, and it seems that most exports still swing hard from a low deadkey.That link incorporates variable power AND the swing mod - all in one. You can substitute up to 1000uf cap @25-35v. Most people use a 470uf and do not notice any difference if using a bigger cap; I did. Just my preference.
Any Cobra 25/29 is going to outperform an export radio in AM mode; the 25/29's just constructed for max mod by design. The exports only offer more power; not better AM modulation. Waste of time making an export try to perform like a 25/29 - JMHO . . .Is there a variable power mod that maintains a good swing ratio? I have never seen one, and it seems that most exports still swing hard from a low deadkey.
I don't need/want a swing kit combined with the variable carrier setting, that's my issue.Any Cobra 25/29 is going to outperform an export radio in AM mode; the 25/29's just constructed for max mod by design. The exports only offer more power; not better AM modulation. Waste of time making an export try to perform like a 25/29 - JMHO . . .
But you wanted to do that with a ept3600xxx chassis? All that cap is doing is allowing peak watts to get through. However, if you don't want it to swing, all you would need to do is not install that cap.I don't need/want a swing kit combined with the variable carrier setting, that's my issue.
I don't want the radio to exceed the proper modulation setting regardless of carrier setting, I guess it's becuase of the transformer modulated high level design.
Still I just want to set a Cobra 29 @ .5 watt and get 2 pep, then 1 watt to 4 pep, then 4 watts to 16 pep, this mod will NOT allow this in a simple twist of the knob.
Indeed the "swing kit" is combined with the variable dead key in this mod no-matter-what.
The only work-around to re-tune the radio for the required carrier level, every. dang. time.
All i'm saying is that I want my Cobra to have a variable dead key that doesn't screw up the purity of my signal (harmonics, over-mod, bleed-over) just because I changed the carrier adjustment..But you wanted to do that with a ept3600xxx chassis? All that cap is doing is allowing peak watts to get through. However, if you don't want it to swing, all you would need to do is not install that cap.
You won't see 20w from a 25/29; the stock final is only good for 10w. Anything over that will be distortion and/or 54mhz trash. Unless you install a MOSFET or 2sc1969 to get more watts.
