ALIPHATC SOLVENT, and NAPHTHA are first on the list, and smell like hellNot sure whats available in the states. Silicone sealants here are available in neutral cure or acetic cure. Acetic cure dry faster and are stronger.But they tend to start corrosion on bare metal . I have seen wire and auto panels eaten through after using acetic cure RTV silicone.
If you are unsure a good tip is the acetic variety smells like vinegar.
I'm going to see if I can find anything about there corrosiveness on line real fast. Here in the states it is used by most to seal (power) wires from the weather.
I have been using it on coax for years to seal the ends but never "looked inside" to see if it did any harm.( I change my coax once a year on my mobile ).
