Hey everyone
I'm trying to modify a new radio. It's a Midland 77-883 AM only radio. PCB is marked as PC-152AC. It has an 858 PLL which I was really looking forward to modding until I ran into a few issues. Perhaps they're not really issues as much as confusion on my part.
Here is the website where I'm getting the mod info from.
http://kg4zpn.netai.net/cb/pllfreqmods.htm
Specifically the very first mod under the list of UPD858 mods.
The problem is that the circuit in the radio doesn't quite match what's in the diagram shown here. In the diagram pins 20,22, and 23 are shown as grounded. Pin 21 is shown as connected to 5V. Pin 19 is where you cut a trace and add a resistor with the switch.
The configuracion in the radio is completley different however. Pins 20 and 21 are connected together. 23 is grounded and 22 I believe is used for binary input.
The mod info does not mention anything about grounding the pins the way it shows them in the diagram so I think it assumes that the radio comes this way from the factory. The only pin that I could really manipulate according to the diagram is pin 19. The rest I wasn't sure what to do with. I was wondering if I could make the rest of the pins match what's on the mod diagram but I'm afraid of damaging something. With pin 19 set up as the mod diagram states but the rest of the pins left untouched, the mod does absolutely nothing.
Does anyone know what can be done about this situation? Can the radio be modded at all? The radio uses a 10.240 crystal. I can't find any other info on this radio or on this chassis.
Attached is a picture of the chassis. The PLL/VCO circuit is in a completley seperate module that solders onto the board.
Your help is much appreciated, thanks!
