148 gtl made in china
I have an issue with this radio,the final fried i replaced it also after that no am power or modulation but i do get modulation on usb and lsb, seems could be the audio amp ?
I am thinking like leapfrog is as to the AM reg may be out. it is a 3 legged trans and should be mounted in the back of the radio. it is the same size as the final. I think it is mounted on the back side, could be wrong on this radio but take a look to see if you can find it. if SSB is working good as you stated I would be checking the reg. a tip42 will work in this spot for a replacement.
Intresting find i believe smd resistor has gone bad but there is no info on the schematic what value it is i also tested it has zero info on it.below is a picture where it is located crosses td2003 pins.
