What brand of screwdriver antenna is this
Here are pictures of the base with a steel rod and the threaded mounting bolt. There appears to be an insulation spacer between the outer wall and the inner tube that the steel rod slides into. What I don't understand is why there would be continuity between the outer wall and the mounting bolt if the mount is to be isolated from the rest of the antenna.
So their is an insulator... Odd that you are getting a resistance instead of an open or short circuit. If it were an open circuit I would say it was a capacitor and part of a matching system. Their aren't very many reasons that you would want to have DC resistance on an antenna as DC resistance translates directly to heat loss. I wonder if their is something else going on...
Looking at the image it looks like their is a screw that makes it to the center part of the tube. Does that screw make it all the way to the outside? Looking at the provided images above it appears to go all of the way out, and it appears their are 2 or 3 that do the same. That being the case I'm surprised that your multi-meter isn't simply showing a short circuit, unless perhaps said screws weren't tightened down all the way when the reading was taken?
The DB
The DB
You are correct. The screws were not fully tightened. If they were, they would result in a complete short. The more I delve into this the more I learn and the more questions arise. The three lower screws appear to ground the matching coil. Shouldn't the body of the antenna be isolated frm the ground?
You are correct. The screws were not fully tightened. If they were, they would result in a complete short. The more I delve into this the more I learn and the more questions arise. The three lower screws appear to ground the matching coil. Shouldn't the body of the antenna be isolated from the ground?
When it comes to RF things get far more complicated than DC. The inductor, which at DC appears to be a dead short, can appear to be any number of things to an RF circuit, and if designed a certain way can even appear to be almost an open circuit. This is how many RF chokes are made, and will allow DC to flow freely but block RF of certain frequencies. This is a more extreme case, but just because you have a DC short does not mean it acts the same at RF. The shunt coil mentioned above also presents a DC short, but all it does at RF frequencies is modify the impedance between the feed line and the antenna as a means of matching.
The DB
Reactions: 738 and KMJensen
Not sure why that insulator would be there except possibly a bushing to fill the gap.
Yes the entire antenna has to be isolated from ground. The matching coil must short to ground though but will have no adverse effect on the antenna. That's why I posted earlier a lead, preferably a piece of enameled wire would have to come off the coil and go to ground.
After looking at those pics some more, I don't see how the coil would work because the entire coil isn't isolated and both tap point screw touch the antenna body too. If that lower section was isolated from the rest of the antenna then possibly.
I would bypass it and go with a 9 turn shunt coil and be done with it.
That antenna appears to been mounted using a stud mount and ring terminal for the coax. You can use this type or the typical SO 239 stud type. Both of these use nylon insolators to keep from shorting the antenna out.
Sere pics below.
SO 239 stud mount with white nylon insolator.
Ring terminal with 2 insolators that go between the mounting bracket. 3/8 x 24 bolt to go into antenna base. This is what your antenna previously used except he top nut wasn't.
Typical mounting configuration so you can see how the antenna is isolated. You can use either type to mount your antenna. You can use one like this with or with the top nut. You will need a 1 inch piece of all 3/8 x 24 all-thread to use the top nut though. Most CB dealers sell these.
if it works as i imagine you need the insulator to support and insulate the coil,
imagine the shunt coil setup been on a former stuck into the bottom of the antenna rather than dangling in free space,
then imagine taking the coil away and cutting the 9 turn coil into the bottom of the tube shoving the insulator up inside to support it
the screws short the coil to ground for bands where 9 turns is too much,
feed it at the solder tags.
Reactions: 738
So does the shunt coil work across 10m to 80m bands? I'm curious as to how the shorting screws work in the original design. I will say that I am learning alot from this thread and all who have contributed so far.
Yes and no. On lower bands like 80 meters, the coil may have to be re-adjusted or more turns added because the feed point impedance lowers even more. You can adjust the coil for a good balance between 80 and 40 and probably 20 but then 17 meters and up will have to be re-adjusted. This is the trade-off for running 80 meters on a shortened mobile antenna. 10 thru 40 will average out just fine with a single shunt coil.
I've got away from shunt coils and moved on to dual UNUN transformers that I modified with a toggle switch for easy switching between the upper and lower bands. I'm going to modify it more with a relay switch so I can remote switch it from in the vehicle.
Your antenna has the same coil diameter and about the same coil length as my screwdriver antenna so I can say yours will only tune down to 40 meters. 80 meters on a mobile is about as in-efficient as you can get and 160 meters is even worse. The efficiency rating on an average mobile antenna for 80 meters is less than 2 percent. So with a 100 watt rig, your ERP is barely 2 watts. The 160 meter ERP is in milliwatts! There are ways to get the efficiency increased on 80 meters with a screwdriver antenna but it's only for stationary operating. You can inquire about that later on if and when you get this antenna going.
That original matching coil design is a bit baffling. If we saw a complete version of it we would most likely be able to figure it out. To me it seems that one end of the coil be connected to the antenna body the rest of the coil would have to be isolated from the antenna body, then have specific tap points on the coil and be shorted to ground to work properly. If the coil wire was enameled wire, those tap screws wouldn't make good contact. If it was all bare wire then the coil would be touching the antenna body and those tap screws wouldn't make much difference.
Reactions: 738
I was recently given a screwdriver antenna by a non ham. Can anyone give me an idea as to what brand or model screwdriver this is? Also, can you explain what is missing from its base? I'm assuming that it is the matching coil and tap points but am to new to the hobby don't completely understand myself. I'm looking for any information that will help me put this antenna back into srevice.View attachment 20550 View attachment 20551
I know this is a old thread but it looks like an early Alpine Antenna. Wes made his just like that with the stud and the coil turns on the base so no shunt outboard was needed. I had a couple of them. He is silent key now.
Reactions: 738
View attachment 20557 View attachment 20558 View attachment 20559 The top coil has approximately 150 turns. Here are pictures of the base with a steel rod and the threaded mounting bolt. There appears to be an insulation spacer between the outer wall and the inner tube that the steel rod slides into. What I don't understand is why there would be continuity between the outer wall and the mounting bolt if the mount is to be isolated from the rest of the antenna. View attachment 20557 View attachment 20558 View attachment 20559
I know this is an old post, but curious if you ever did anything with it. I was just given a new one in the box. It's the original DK3 screwdriver antenna...
Reactions: 2RT307
I know this is a very old post from 2017 but if the OP is still monitoring this, YOU HAVE A PIECE OF RADIO HISTORY IN YOUR POSESSION.
That is the ORIGNINAL Don Johnson DK3 and it is a fabulous HF screwdriver antenna! My first remote tune antenna for the vehicle was from Don directly purchased in the mid 1990's from him at a swap meet in Northern California.
I have since moved on to other screwdriver antennas because I run 1/2 KW mobile and would burn up that coil form in a few minutes with power. That antenna handles about 200W PEP 100W DC while in operation mobile.
The grooves machined in the base of that coil are the "shunt coil" for allowing it to work broadband from 80 thru 10 Meters with a 6 to 8 foot whip attached to the top of it.
If you still have it, it is a piece of HAM radio history I would not part with it as they are sought after as a really good working antenna for HF mobile operation.
I built a coil cover out of PVC pipe thin-walled and caps to protect and keep dirt out of the tuning coil and finger stock. However, Don used to recommend using a shock absorber boot like on motorcycles and off-road rigs that had an accordion rubber boot over the steel piston shaft. They work but can get pinched in the finger stock so I used one from parts at the hardware store.
You could probably also contact Tarheel antennas and buy a ready made raydome cover for it from them for a reasonable price that won't look home made. It will finish off that antenna real nice with a Lexan cover for it.
Just thought you all would like to know what this was.
73 de RR
I see the post above shows the writeup from Don. He used aluminum irrigation pipe as used for fields in the central valley to water crops.
He used a muffler expansion tool to flare the end so that the finger stock could be placed inside the opening.
Many used a CB antenna whip cut down to 72" (6Ft.) on top and I have used a Master Mobile lower mast with a 24" diameter capacity hat to get more efficiency on 3.7MHz (80M) band.
Good grounding is essential and to power the motor, some power resistors were in the control box dropping voltage roughly in half so the Skill Twist cordless screwdriver motor won't burn out.
A momentary UP/Down double pole double throw switch cross connected inside controls the polarity so the motor moves properly.
Tuning is super easy, tune for maximum band noise on your receiver, then just touch it up under low power (10W) give or take until your VSWR is below 1.7:1, you're good to go!
I have worked the world mobile for 30 years on a screwdriver antenna logging over a half million road miles with this type of antenna.
73' de R_R
