President Grant II
9C1Driver
Aug 13, 2008
4,295
2,283
273
Trying to find some mic wiring information on this 6 pin radio. I'm hoping it's the same as Magnum 6 pin but since one of the pins is hot I'm not plugging a Magnum or RCI mic in until after I know for sure. Does anyone also know which trimmer pot will adjust the AM carrier? I will open up the radio here when I get a day off work and see if the board is labeled, that would make it easy.
Popped the cover on this radio last night and WOW, that SMT electronics is tiny tiny tiny. I don't know how anyone can even work on that stuff.
mic wiring page 52 of manual
have included board map showing adjustments
  • Grant_II_ASC_EN.pdf
    Grant_II_ASC_EN.pdf
Thank you for the reply. I ended up finding the mic wiring in the manual as you posted. Also have the AM carrier down where I need it. Seems to be a great radio, take care.
