Initial Ham Setup
Riverman
Nov 12, 2013
3,080
3,466
273
After much consideration, I've decided to go with:
Yaesu FT-450D
Mega Watt S-350-12 power supply
And a couple of dipoles (6M &10M) to get me “on the air” as a Tech.
Once I pass my General, I’ll look for a good multi-band.
I know the current solar cycle is in the dumpster, but I’m excited anyway. After all, there are worse things in life than limited radio contacts.
A happy and meaningful Memorial Day to you all!
Jim
I'm glad you have narrowed it down. I am not looking forward to sifting for days on end to decide what I will get.
I finally decided after carefully reading the instruction manuals for all the radios I was looking at. In the end, the 450D felt like the best fit for me. And my budget. LOL.
When you get your general get this antenna along with the 1:1 choke for the feed line.
I run the IC-746 as my primary base and use the 50 amp Megawatt power supply. I have a bunch of radios and antennas for mobile but nothing in the 2 meter band at all.
If you don't like the antenna you will not have wasted a ton of money and you can take the antenna down and take it with you on vacation.
I have made a bunch of contacts with it with no linears.
Yaesu FT-450D
Jim
Good choices!
At the moment, 10 and 6 has been opening.
Not sure if you have your Tech license yet, if not as long as you're in study mode, get your General the same day. You can do it!
Good luck!
Reactions: Sonar
Good choices!
Good luck!
That's good news!
Still studying for both. Been a LONG time since I've had to take any kind of test LOL.
Yaesu FT-450D
Jim
The 450D is a good choice. Don't be discouraged by the solar cycle, just get on the air and call CQ.
That's good news!
I don't know how you are studying, but the flash cards on hamstudy.org have been a huge help for me. I have gone from 35% on the tech tests to 80%+ on the general in about 8 hours of studying. I didn't think I could pass the general after trying the tech, but it is easier than it seems. Best of luck
Reactions: CB590 and Sonar
Am using "The No-Nonsense Technician Class Study Guide". Will check out the cards at hamstudy.org. Thanks!
