Just curious to know why some export radios dont have a meter showing db gain and rf power etc. ?
F*** :-(In the upper right hand corner of the display it shows the roger beep enabled. Operator error![]()
It may be nothing . Do you have another receiver you can listen to your own signal on?? The original longer hang time after you un-keyed was definitely the roger beep.
I think you need to be able to view on a watt meter or listen your output on a separate receiver to really see if the momentary spike on the LED display is anything to be concerned about.
Agreed. I was thinking it may just be the meter showing a voltage spike from the metering circuit switching from TX to RX. An analog meter would never respond fast enough to show it. Nothing to worry about or even pay attention to IMO.
