A happy medium , SWR , Watt meter recommendations?
Limeybastard
725
120
43
55
Shady Hills Massive, FL.
Was hoping for a little input from you forum vets. I am currently looking at buying a SWR , Watt meter on a budget, any recommendations? Originally wanted a SWR Watt and Mod meter, but after reading reviews of a few in my price range that idea took a dump. Then I started researching Dosy for watt and swr meters, that also took a dump, again for being very innacurate. I can live with 10% plus or minus.
My current Amazon Workforce SWR watt meter took a dump, luckily it was within its 30 day return window. So on the prowl for something to show me a relative acurate SWR and W readings. Ideally Id opt for an LP100A, but cannot justify $500 price tag.
Cheers.
Limey,
I have a Diamond SX-200. Covers HF, 6 meters and 2 meters. (1.8 to 200 MHz).
Paid $90 for it new. Very happy with it.
The CN-801 is versatile and relatively inexpensive.
Daiwa meters definitely.
I use the Ameritrons AWM-35BH because I like the remote sensor that let's me mount the meter anywhere and I don't have to route the coax to it. The remote sensor stays hidden away, it just runs a Cat5 cable to the meter.
This works great for mobile and in the shack.
I wish Daiwa would make a remote sensor type.
Most of the ones mentioned above are accurate enough but not scientific. If you want that, go with a Bird43 and you'll need different slugs for different power levels.
The cross needle meters used for Amateur frequencies I'm aware of are selectable peak reading and require 12v to operate the power meter circuit. The CB types like the Dosey and Astatic only require 12v for the meter light so I question their peak reading capability and accuracy.
Reactions: Tallman
    boog351 has left the room.
