Need help!!!
Occasionally when taking off from a light it will look like someone keyed up to then drop down to 1 s unit until I get to cruising speed I ordered ferrite beads and 0.1 if caps so see if I can make something happen gonna move my coax so it's not ran along the floor on the side the fuel pumps on
On another note once I drill the hole will I have any issues running my messenger 9 pill it's 1446 transistors wondering if I need to worry about computer in truck or not?
Your going to need a heck of an up-grade in the alternator department to feed that amp. Might as well get a big new battery as well.
As far as your noise, the electric fans on the radiator of certain Fords cause problems as well. Good luck.
I got the noise deal fixed had to make a choke I got a 120 amp alternator now but not doing good on the battery situation 120 amps be enough?
