Skipper by Polomar
Delta 1
Well-Known Member
Mar 11, 2016
192
110
Lompoc Ca
Looking for a little help.. just received this in the mail today.. my ? Is is there a fuse inside the box itself.. or do I need to put one inline.. not even sure what and how many pills are in it.. the seller didn't know anything about it ( never opened it).. looks like a hassle to open it up.. so before I do all that, I was hoping someone here (forum) can give me some insight on this amp I really appreciate any help.. Thank you.. IMG_20180104_174934607.jpg
Those are very easy to open. Take the four black screws on the faceplate out, it will stay in place due to things still connected. Then tilt the faceplate up a bit and slide the bottom cover out. All of those should have a fuse on the board. Great amplifier by the way.
Yep got it open, there's a 25 amp fuse on the board... Got it hooked up and running , everything function's probably. Thanks for the help and 73 your way.. Delta 1
