Grounding
Pman62
Nov 20, 2017
47
20
18
64
Now I know that grounding is NOT an option with antennas, but I have never found the grounding requirements for dipole antennas, more specifically inverted V antennas. This may sound very newbish, but how would one go about grounding a balanced antenna system such as an inverted V?
You don't have to ground a balanced antenna. With a balanced antenna the RF ground is contained within the antenna itself.
Basically the reason you need a RF ground is to have a source of electrons to draw from and a sink to return them to in order to allow a current to flow in the antenna. With a balanced antenna like a dipole that source and sink are contained within the antenna itself. Each leg supplies an adequate source of electrons to allow current to flow in the other and for those electrons to return to. It is balanced.
With an end fed vertical you don't get that happening within the antenna, the antenna is unbalanced, so you have to have a RF ground aka ground plane otherwise what is going on in one of those legs of the antenna above happens on your coax. That results in a phenomenon called common mode RFI which can result in more noise on receive, your coax spewing your signal everywhere and a humming noise in your audio or distorted audio as you transmit and in extreme cases give you RF burns. Because with an inadequate ground your coax forms part of the antenna the length of the coax can also affect the tuning so if you alter the length the SWR will change. That is how the old wives tale of needing 9ft or 18ft or whatever people say of coax for CB antennas came into being - they didn't understand that the coax was part of the antenna because they had a poor or non-existent RF ground.
With both types of antenna you want to have a RF choke to ensure that you have no RF current flowing on the outside of the coax. The reason you still need one with a dipole is because in real life no dipole is truly perfectly balanced due to the effect of nearby objects on each of the legs.
