Load capacitance for custom IF crystal?
The pace 1000b is in and works. I figured out the strange switch on the side. I bought a Siltronix VFO 90-1 for it instead if the crystal. The midland needs work now that I popped the cover. The chart I looked at stats the 90-1 will work with the pace 1000m which is just the same board as the 1000b, so has the same crystal scheme which I verified using the crystal mixing chart.
K.M
K.M
Hi, I have a Pace 1000B 23 channel, you are saying the Siltronix VFO-1 will work in it? Thanks, Adam
Yes it will Their a lot of VFO out their. the difference between them is the cap used in them I have a chart that shows it some wheir around Hear
Hi, I now it will work but there are 3 versions of the 90-1 which have 3 different frequencies, I need the one that is 11.990 so not sure if the others will work. Thanks, Adam
  • @ Spanish:
    Where do i upload schematics
