TS 500v - fan recommendation
SuperDave
157
9
28
Luling, La.
I'm looking to add a fan over the heat sink on my TS 500v and was looking to see if anyone here had a particular fan model number that has been used for this application already? Also where did you tap in for the 12v power?
I will probably mount it using the plastic dry wall anchor method.
Thanks!
I use fan like this with some double sided tape to keep it on it’s been on a few years
Thanks!
If you can find a 4-5 inch 24 volt fan they work great at 13-14 volts, nice and quiet.
