Twin Fuse Power Cord
And my newly acquired Kenwood TM-V71A as well. It has TWO fuses in the power lead and Kenwood recommends running power directly to the battery for BOTH leads.
when i wire a radio,i prefer to go directly to battery(s) with both wires,heavier than radio leadcwires.i install fuse holders just upsream from battery just incase a wire moves,gets pinched,insulation damaged and shorts out.i put a size bigger fuse up near batterys than radio requires but use what radio requires in its leads.if wire does develope trouble it dont burn up vehicle
