Has anyone had any luck taking apart the base coil on a wilson antenna?
Hi all,
i have a wilson 5000 antenna just sitting in the garage because of a bad solder connection on the coil.
i would like to crack it open and fix it, but years back i tried to get an old wilson 1000 base coil open and damn near destroyed the thing in the process.
so does anyone have any secrets for getting these open without ruining them?
maybe heat?
a certain solvent?
repeated hammer banging at just the right interval in order to cause resonance to shake it open?
thanks for any and all tips and advice.
Since it is thermoplastic; did you try gently heating it up with a heat gun/blow drier?
Putting it back to together might be a lot easier after that.
I like where this thread is going lol.
'if it breaks, F it. just make another one!' you guys think like me.
I own all the tools you guys were talking about, but if im willing to lose the material that would surely get lost in the cuts, then i might as well just cut the thing around the outside and then glue it back together.
I still might end up doing just that.
Please repeat after me......
I have done so much......
[Repeat]
with so little......
[Repeat]
for so long.......
[Repeat]
that I am now qualified......
[Repeat]
to do anything.......
[Repeat]
with absolutely nothing!
[Repeat]
So help me God.
There it is now official.....You are now qualified to tear up a tank with a rubber hammer. (y)
LOL im going to pin that up on the wall in the metal shop!
Robb, i have not tried with the heat gun yet, and was going to until i read of someone else who tried it and it did nothing.
however, i have no idea what kind of heat they were using or what kind of experience in this realm that they had so it might still be a viable solution.
as of right now, im still intrigued by autotuner's idea, but im thinking even more off the wall.
what if i filled it with water and then froze it?
it would have to burst somewhere right?
So you want to freeze it......submerge it in liquid nitrogen and shatter it with a tuning fork. :eek: Though Autotuner has a much more spectacular approach. Maybe a blasting cap and a old crank telephone posted on Youtube? o_O
Water? Mmmm; dunno.
Don't think that enough water could get in there to make it split.
If splitting is the real solution; then using a Dremel tool with a cutting wheel might git 'er done . . .
well the gun powder idea was super fun but didn't work very well:
65388d1338490515-cb-antenna-destroyed-003-jpg
JK this is a cheapo cobra antenna from a 4runner forum.
I would suspect that freezing with water would split it straight up the weakest side. I have my old Wilson 5000 sitting in the corner with a broken coil. I am really liking the PVC coil idea. I would suppose that metal would be ok too. The Stryker has a metal case around its coil. A short piece of fat aluminum tube would be handy right now.
Reactions: Redbeard U812
Just use fire!! I’m on a burn-it kick lately, just kill it with fire.
It’s not going to abide easily, so violence is the answer here. You’ll most likely never get it apart where you can put it back together again, so again, violence. Haha.
