Ring modulation???
Mar 25, 2019
72
12
18
42
how would I go about applying a ring modulator to my cobra 2000? Guessing tp7 and tp8 have something to do with it.. what other things are needed? Radio is already direct injected just curious what the gains are? Thanks a lot any input would be great
Never heard of it. Where did you read about it or see it. Some additional context as to what you're after would be helpful.
diode ring modulator
double balanced modulator
https://www.robkalmeijer.nl/techniek/electronica/radiotechniek/hambladen/qst/1993/12/page32/
discrete diode modulators are a bit archaic but so am I .
If you want to play with dual sideband suppressed carrier that's fine.
It's actually a step backwards in most cases.
