antenna ground plane kits
Straightshooter58
57
29
28
72
Rockwall County, Texas
making a temp antenna using either firestik 5 ft or 102 in whip as a base. been looking at Tram 1470/Harvest 1401/Negoya ground plane kits for 11 meter use.anyone have any exp with these ground plane kits that use a mobile antenna as a base..and are any worth a filp? Thank You. Old Guy In Texas.
Have made a ground plane using three 4' Firestiks. One for the vertical element and two for the radials (angled down @ 45 degrees). Also made two dipoles using the same antennas. One horizontal and one inverted V. All worked well.
Couldn't find the thread on my ground plane but did find the other one:
https://www.worldwidedx.com/threads/inverted-v-attic-antenna-using-mobile-whips.183341/#post-517741
Reactions: 357magnum
e33ff22607f7d1b3b5eb70a96edb8f8032955a76-1.jpeg e37492a671b2a6fd613c164799199bbcf2d98bd3-1.jpeg
That's an old Realistic/Archer/Radio Shack 5/8 bracket with a home built insulator at the bottom. The black box is a SGC SG-230 remote tuner. The whip is also SGC. SGC telescoping 33' marine whip. The ground plane is fiberglass whips of various states of decay that would be dangerous or negligent to put on a mobile.
The ground plane has since been replaced by 36 below ground radials .
The post in the ground is also the vertical test stand for all manner of goofy and weird RF .
ButtFuzz isn't the only mad hatter here.
Made and seen many of these. Use a Trucker Mirror Mount for the base. We used to have a local supplier for 5/16 solid aluminum rods that we bought for the ground radials. Use 3 or 4 of them. 102" whip for the radiator. The guys called them Homemade Stardusters. They worked fine.
Copper wire for my 1/4 wave radials also, set our cabin station up with just 2 it works great for what we use it for, 4 on the one at home , used that design that BJ posted
Reactions: binrat
