Galaxy 98VHP Alignment Question For The Experts
So if I was to use the spectrum analyzer to do the bias for clean output and linearity; I'm assuming adjust for lowest reading on 2nd harmonic should work? Or just look for any spurs around the fundamental? Thanks
I must emphasize...
Yes! Wholeheartedly!
But not just on Bias, but for the WHOLE TX Strip.
I've seen several radios' - their power "dimmed" because they (whomever did the final tuning before packaging) wanted to just remove a "spur" or "tone" (noise) they noticed...
A radio right out of the box directly from the factory, is a good radio.
A great radio is one that has been tuned up properly by one that stands by their work and their equipment.
I've had Unidens, Galaxys, Cobras - Midlands, Tandys and just about any other radio that is out there - flow into the shop with a note that it is requiring a tune up because the "meter swings backwards" (or insert favorite complaint here) - well it does, because of issues.
One of the main ones, being what this thread is about. Bias. But that in itself is not the total fix.
(y)(y)
