Need help with some math. Building a low pass filter
loosecannon
Mar 9, 2006
4,420
4,073
273
Hello all,
I am looking for some help with filter design.
Not necessarily how to figure the parts values as there are plenty of online calcs for that.
What im looking for is how to figure out the voltage rating of the shunt capacitors.
for example, if i wanted my low pass filter to be rated to handle 2000 watts continuous, what voltage rating of capacitors do i need to use?
Thanks in advance for any help on this.
The formula I've been using came from an AG6K article. The exponent didn't copy and paste right. 20.5 is actually 2 to the .5 power. http://www.somis.org/bbat.html
"The RF-peak-voltage that appears across the capacitor varies widely depending on the feed-line Z and the power level used. The voltage can be calculated if the impedance and power at the feed-point are known. The formula for calculating this is E= [P x Z]0.5 . Since P is measured in RMS-watts, the AC voltage (E) result will be in RMS-volts which can be converted to peak-volts (e) by multiplying the result by 20.5 . For example, if Z=600ohm and P=1500W, e= [1500W x 600ohm] *20.5 =1341v peak.
When using a vacuum variable-capacitor, it is important to realize that the maximum RF peak-voltage rating at 30MHz is usually 60% of the rated DC / 60Hz peak-voltage rating. Thus, a "5000V" rating translates to a 3000 peak RF-volt rating."
This is true. I just gave him the numbers for 50 ohms since I assumed that was what he was looking for. In any event the LPF would have to be designed for the impedance of the system hence my assumption of 50 ohms.
thanks to both of you for the answers.
looks like RMS is 316.23 volts, and peak is 447.21.
Im just going to go with 1kv caps then because why not.
Yes, i could have gone to google and found the equation myself, but i like to use this forum for the great resource that it is, and in case someone in the future has a similar question.
Another useful formula that I picked up from a guy. Rf current can be figured by amps x amps x impedance. 800 watts into 50 ohms would be 4 amps. 4x4x50=800. This is 800w carrier no pee e pee.
There is a way to work it the other way if you don't know current but I'm not a math wiz. I plug numbers in until I get the wattage I'm looking for. Use larger conductors than you would for DC. Think skin effect.
Reactions: loosecannon
You can find one thing if you know the other two.
Reactions: L2 and binrat
I've got one of those ohms wheels up on my bulletin board, but i assumed that there was something more complicated going on since i am dealing with RF voltage.
using ohms law gives you 325 volts, and using the formula that 543 linked to gives
316 volts RMS and 447 volts peak.
CK, are you saying that the other formula is not needed and i can just use ohms law when working with RF voltages?
trying to learn a bit here.
I rounded to 325. My numbers are RMS. 325 volts is actually 2112.5 watts into 50 ohms. Exactly 2000 watts is 1997.12 watts.
I think the formula referenced above
Should be expressed as ((Watts x Resistance)*2)^.5
To the power of .5 is the same as square root.
The expression (1500x600) * 2^5 does not equal 1314.
1500x600 = 900000
2^.5 =1.414
90000 x 1.414 = 1272600
On the other hand
1500 x 600 = 900000
900000 x 2 = 1800000
1800000^.5 = 1314
I hope that helps you figure out what caps you need!
And to Mr 543 - Thank you for posting that link. Man, lots of great information. I really enjoy learning from others on this forum and I hope I can contribute even just a bit.
    63Sprint has left the room.
