1/4 Wave GP Help
Riverman
Nov 12, 2013
3,058
3,404
273
Don’t know how many times I’ve thrown together a quick one. But today, my 102” steel whip and a 102” wire radial is giving me a SWR of over 5. Checked coax, it’s fine. Any ideas?
Thanks.
If it has only 1 radial it behaves more like a dipole. For a dipole close to the ground there will be potentially significant ground and nearby objects interaction. Also, while a 1/4 wave GP may be tunable with a 102" long vertical, that is, in my experience too short for a dipole on 11m.
My advice is to add at least two or three more radials and lower the ends equally to get the impedance right and the antenna should tune.
Someone else may have a different take on this.
Reactions: Marconi and Tweek
I’ve had good success with antennas using only one radial, but in hindsight, my past ones were all much higher. :whistle:
Good catch. And thanks, Homer. (y)
Reactions: HomerBB
Hold on. Got a fly in the ointment.
I kept thinking even with it being low and perhaps a few inches off on length, the SWR shouldn’t be that high (5.2). So I removed the 102” steel whip and the SWR didn’t change at all. o_O I’m thinking I have a bad stud mount. And that the antenna I’m measuring is the coax, metal tripod and wire radial.
Any thoughts?
Check the setup for continuity with an ohms meter. Homer is right if it checks OK.
Try lowering the radial angle and secure it with a wood or plastic peg about an 1" above ground. You could raise the antenna a bit higher if you need more radial angle down to see a better match.
Not a good idea if pets or humans can get into the wire however.
Reactions: 2NC995
Check the setup for continuity with an ohms meter, but Homer is right if it checks OK.
Not a good idea is pets or humans can get into the wire however.
Checked continuity yesterday and is fine. Reinstalled the whip. Left radial as is (16.5’) 3’ above ground. Too tall for dog, no kids. Drove to Love’s truck stop and bought a new stud mount. Returned, installed it and SWR dropped from 5.2 to 3.2! Shortened the radial to 8.5’ and SWR dropped to 1.16! Happy days are hear again! :ROFLMAO::ROFLMAO::ROFLMAO:
Well, now, you never told us you had a 20m 1/4 wave GP laying on its side with a too short single radial pointing up...
In that case we'd have told you to cut that 20m horizontal (somewhat) radiator to ~8.5' and resonate the vertical radial as your 11m dipole/GP.;)
Homer, the effects of time and things just change. I read the 1st post as two wires 102" inches long.
Reactions: HomerBB
A small detail overlooked. :p
Reactions: HomerBB
Sorry for the confusion. 1 steel whip and 1 wire. It’s this antenna without the Chameleon matching unit and with the radial shortened to 102”. (y)
Hey man, you're reading my mind. That was fast work. That coil probably got you closer to were Homer first suggested...as the possible fix he suggested.
You might be able to get the match near perfect if you raise the antenna a bit to allow for some more radial angle, even with only 1 radial, slanted down at the correct angle. You can also play with the length of each element from 102"/108" inches too.
The slanted down radial is what helps improve the match the most in this case. You may have to go higher to keep the radial above the ground a little however.
Write your reply...
  • @ Crawdad:
    Will do Gary, thanks! Hopefully see you Friday next.
  • @ Crawdad:
  • @ W4KVW:
    Rock Stars ROCKS!
  • @ Crawdad:
    Looking forward to it Gary!
