I have found some different things listed for these, one is that you just replace the final with a 1969. According to the schematic from CBtricks I saved, it looks like the driver, TR8, is a 1957. I tested the 1969 before installing, and it showed a Hfe of 143. My output went from a 2-5W to a 1-2.5W output. Nothing in the directions I find say to change anything else, but is the driver sufficient?
Also, I found this:
Cobra 25 GTL/LTD/CLASSIC
SAMS PHOTOS: 207
AM LIMITER: D-9
POWER TWEAKS:
1. Change R76 (3.3k) to a 1k (located near mike socket)
2. Change R43 (10 Ohm) to a 2.7 Ohm.
3. Change R108 (1 Ohm) to a .47 Ohm.
4. Replace stock final with a 2SC1969 transistor.
5. Re-tune coils L10,L9,L8 for maximum forward power.
L8 and L9 are just coils, look like the traps, so I didn't touch them. L10 is the external wound with plastic housing style.
I also found this on Coppertalk, listed for the WX NW ST specifically:
AM POWER: ADJUST ~ L18, L17, L14
AM MODULATION: ADJUST ~ VR5
SQUELCH ADJUSTMENT: ADJUST ~ VR4
"S" METER: ADJUST ~ VR1
RF METER: ADJUST ~ VR7
L18 is a double can, L17 and L14 are single metal squares. Turning them, the DK maxed at around 1W.
Did I screw up and wasting time and radio? Do I need to change the driver to a 2314 like in the thread https://www.worldwidedx.com/threads/cobra-29-high-power-mod-with-2sc1969-transistor.31449/ mentions?
Also, I found this:
SAMS PHOTOS: 207
AM LIMITER: D-9
POWER TWEAKS:
