Ok, it is a quarter wave antenna then, It will be great broadbander, good for more than just 11 meters, I might have to play with building something like this
I would love to replicate this antenna, I really like the performanceOk, it is a quarter wave antenna then, It will be great broadbander, good for more than just 11 meters, I might have to play with building something like this
Thanks for the reply, the antenna offers great performance for what it is. For a portable I could not ask for better.I have a discone in the mmana model software, it does not have the whip on top, but in model, it shows less than one dbi gain, pattern about the same as a 1/4 wave ground plane. So a 1/4 wave would out perform a discone a little, but not enough you would likely notice, I would think the added whip with the tram design brings it up to equal performance to the groundplane antenna. All you would need for ok performance, and all you need for portable. On portable it becomes more important where you put it than what it is, if you can find a good clear hill, it will work quite well. As a base antenna it will be useable, if you get it up 50 feet to the top it will work good. It should perform equal to a vertical dipole or 1/4 wave ground plane .
Yes looks ideal for portable.I have been running a vertical dipole, it works well enough, the nice thing about portable, is if you find a nice hill, you can have great comms. Any kind of gain antenna is not worth the effort for portable. Nice thing about the tram, is that broad banding makes it great for all sorts of bands and scanning, so it offers everything you could ask for on the go. My dipole is single band for sure. I will keep my out for one of these. I think it is a very interesting antenna, lotta bang for the buck.Thanks for the reply, the antenna offers great performance for what it is. For a portable I could not ask for better.
I have found with all my antenna testing that close in 10 miles out anything will work well enough, out 30 miles the difference between a 1/4 wave and something with double the gain like a quad is huge..
I have found the better the antenna the better the dx, I had the same antenna on 2 towers here, One at 30 feet feed, one at 45 feet feed, the higher antenna does the skip, the lower one does not. I have a horizontal on the 30 foot right now, USELESS. I need to get it up higher, maybe my next project.True enough. From a perspective that is purely mobile...
DX is where I see a big difference in antennas. For example, testing on my own using an S meter, it’s exceptionally hard to see a difference with any mobile antenna from 5’ - full 1/4 wave.
And when DX is good, a Wilson 1000 on the roof of pickup will work it.
But there is zero question to me the a 1/4 wave whip is vastly superior in DX. The difference when testing local is little more than a sliver of an S meter needle...but the difference in DX is contact or no contact.
Well I have only tried the 1411 6ft off of the ground and it works well, when I get back to TX I want to order another (along with an A-99) and throw them in the air to compare the results.On my mobile I have been running a President Texas riding around, and a 102” for DX. I can’t find a LICK of difference testing local...but I’m shocked at the difference in DX.
Just over the past few days I’ve decided to run the whip full time. Tied down for driving around town, and upright for DX. No more climbing in the bed to swap antennas. So far so good...and it works pretty good tied down, too, since I only need to reduce the height by a bit.
Where’s the mount? Toolbox?
No...right on the roof.
And you’re at/under 14’? (My big truck limit).
