Ok, I have been reading the "good book of K0BG", and bonding, common modes, etc. This has given rise to a few questions, thoughts, ponderings.
My 78 CJ5, with fiberglass tub, fenders, windshield frame, steel hood, and steel grille, is the vehicle. If has a Mustang 5.0HO with Ford factory EEC-IV A9P Ecu, in-tank fuel pump.
Antenna is a 102 with HD spring, mounted on right rear bumper mounting bolt, ground strap from angle iron bracket to frame. RG8X coax of unknown brand, will be DX Engineering RG8X here shortly.
TRC465 radio, previously Cobra 25 NWSTWX.
Stereo system - Blaupunkt Amp1504, Panasonic head unit, 2 6x9 speakers.
OK, I am trying to eliminate the static from the ECU, Fuel pump, and stereo. I have a snap on bead on the coax, a couple inches from the PL259 behind the CB, it was a "what do I do with this extra one" moment. I have one on the dual RCA patch cable, the cable loops once or twice. I did the same with the remote power wire, power feed and ground. No difference. I have no idea what "mix" these beads are. I believe in the Q/A section on Amazon someone said they were 43.
I am thinking I will try the 7 loops of the RG8X thru the Mix 31 like K0BG mentioned when I rework my coax. I plan to add some help to the radio, and re-route the coax down the driver side instead of down the passenger side bundled with the fuel pump power wires. I bought a few toroids of Mix 43 to make a choke for the fuel pump feed wires, but never did. I don't feel like dropping the fuel tank unless I need to do more than the choke. Would this 7-loop-thru-Mix 31-filter work for my noise issues?
I also plan to bond the dual exhaust pipes to the frame at the rear. In the article, he says in multiple places, I am guessing due to clamp-type connections. My pipes are welded. Is a strap on each pipe in the rear enough, or should I do one in front, too? It is a ball-flange type junction to the engine.
Bonding the hood - the braid would be a couple feet long to bond to the frame, and no way to bond to the grille, so should I worry about it? Bond to battery neg?
